howdy,
i dont know how to start this post,firstly who the f*** built our house.over the weekend ive been slugging it trying to get the loft boarded out.what i have noticed is that next to the 2 beams that run across either side there is also a piece of 3x2(2 on opposite walls ) if that makes sense.on each piece there is a strip of metal(4mm.x1" )across athached to it. this strip runs the length of the wood till it gets to the end then bends up and carries on into the breeze block where it has gobbo slapped round it to secure;WTF i cant get my head around it.surely common sense dictates that this isnt going to offer much support to the brick work;minst you the way they have put the breeze block up is shocking to say the least theres joints with nowt in ended up getting a bit p***ed cause i had to cut the chipboard to go round these effages and also one is obstructing the cold water header as its sagging a bit on one side. what does anybody think of this i would like to remove one so the tank can be supported properly. cant help but think that it was a friday afternoon when they put these in.gaffer took one look at brick work and said whack some 3x2 in;nobody gonna see it when the other bricks are up,its not my f****** house!!!
thanks if someones still awake after reading this;the gripes over
