Hi All
We're having a house extension built right now and we have an internal porch to step into from outside, then you have the main front door in the middle of the 3m wide porch area.
The plans show for a 300mm wide block and block cavity wall but as it isn't load bearing we have the option to make it a much thinner and cheaper stud wall filled with insulation.
The internal porch area is going to be K rendered, the same as the outside of the extension. The front door is a standard double glazed stable door that we currently have, it will be moved.
The question...
Given that the door is quite heavy, what wall will be most resilient to the stress that opening and closing the door repeatedly will put on the wall?
My head says go for the blocks but as they will only be 'sat' on the concrete slab and fixed to the load bearing walls with wall starters i'm not so sure. A stud wall could be rawl bolted to all four edges and may even offer flexibility to asborb shock instead of a stiff and uncompliant block wall that may just crack.
Many thanks in advance.
Jono
The question...
Jono
