32 -> 22 solvent weld pipe reducer
2 May 2006
Glasgow
all, fitting a new saniflo pump (i know there c*rap but i have no choice) and i need to fit an air admidance valve to a 22mm solvent weld pipe. the only value i can find is a FloPlast value that fits to 32mm.
anyone know where i can get a 32->22 reducer or where i can get a value that will connect stright to a 22mm pipe
thanks
ewan
i've googled till the cows come home and cant find anything.
no local plumbers merchants so i was hping to find somthing on line.
Do you actually mean 22mm or do you mean plastic overflow?
This is 21.5mm and reducers are available readily from 32mm at plumbers merchants.
