32 to 20mm adapter
21 Jan 2003
Is there such a thing as a 32mm to 20mm pipe adapter?
The reason I ask is that I have a toilet only Saniflow unit and would like to install a sink in the toilet. The sink outlet is either 40mm or 32mm I can't remember and I was thinking that it would be better to attach the waste outlet downstream of the saniflow i.e. on the 22mm pipe rather than onto the toilet with the sink emptying into the pan.
I would be expecting to add in at least two non-return valves to prevent a) the saniflow pumping water into the sink and getting a lovely fountain :eek: and b) the sink draining back into the saniflow.
Does this sound sensible or am I going a bit mad? :confused:
Any help appreciated
Andrew
at BES ??
Thanks very much Chris, that exactly what I am looking for
Andrew
Good fitting that :cool:
Ain't gonna do you know good though.
If you get a 35mm to 22mm reducer in copper, the 35mm end will fit nicely into a 32mm compression waste fitting. ;)
i'm no expert when it comes to bog mechanics, but surely thats a non starter as doitall inferred.
Andrew I have fitted loads of macerators and would advise 32mm outlet to prevent problems in the future.
I know it may say it can pump through 20mm but you are making it work very hard to pump the carp out.
Not to mention the trap siphonage issues too.
Pete
