32mm condensate p trap
Status
Not open for further replies.
25 Jul 2018
I am installing a condensing boiler. This requires a soakaway to take the 22mm outflow.
This says there should be a 32mm p trap and to output to a soakaway in limestone chippings.
I have bought a Plumbright 456944 soakaway but cannot find a 32mm p-trap standpipe only the 40mm one which is used for washing machines of type in pic.
I could buy a telescopic p-trap but this needs to be a minimum of 450mm in height.
Otherwise I could join a 32mm pipe to a standard basin inlet p-trap if I knew what fitting I would need?
Any suggestions?
Get a Gas Registered operative to install the boiler. You are clearly not competent so you're in breach of regulations. You are not able to test the boiler for safety which requires trained use of a flue gas analyser, for example. The condensate is part of the flue system.
This forum does not support diy gas work.
How are you going to register the boiler and carry out FGA readings as required by the Benchmark logbook. Excuse me if this post seems to be a diy effort.
Status
