32mm solvent weld tank connector - what size hole to drill..
20 Apr 2010
Hampshire
Hi
Im hoping someone will be able to offer me some help here - im a tropical fishkeeper and have drilled many tanks for overflows with a diamond holesaw. I now have a requirement to go to a larger size to accommodate a 32mm solvent weld tank connector - the outside diameter of the threads that will push through the drilled hole is 41mm .... thus far I have only been able to find 40mm or 45mm holesaws. 40mm is clearly too small and the 45mm is going to be a bit sloppy I fear - can anyone tell me what size hole I should drill to fit this 32mm solvent weld tank connector...
Thank you
Bungy
you can get a 42mm hole saw or use a 41mm and go round the hole with a half round file.
Brilliant - 42mm Holesaw is perfect for this job then but ive been having problems finding that size - any idea where I can get one please?
Bungy
Ah, this type of holesaw is for wood and the like - im after the diamond core drill for glass and tile.....??
theirs quite a few on ebay from english suppliers.
THATS THE FELLA.....brilliant - ok so now I know they are out there, I just need to find a UK outlet to get one by this weekend.....!!!!!!
You are a star thank you so much.
Bungy
Done deal - found one on e-bay - delivered hopefully by the weekend.
Thanks again for your help.
Bungy
