32mm waste through joist
20 Feb 2021
What would the plumbers do here? I need to get the waste up the back of the wall rather than up through the floor. Access at back of wall is easy, lots of room in the solum. Problem is I have a double 5x2 joist underneath the wall between waste pipe connection in main soil pipe and where I want to run it to. Is it acceptable to cut a 35mm hole in a joist that sits across a 1.6m spanView media item 106106
I would possibly use x2 45 degree elbows to set back to wall
I want the pipe to be hidden though as shelf mounted sink going in. So pipe somehow has to get to the other side of the joist and run up the other side of the wall.
You can drill a hole a hole 25% of the size of the joist between 0.25 and 0.4 along the span of the joist.
