What's the best way to ensure a watertight fit connecting a 38mm European / continental waste pipe to a 40mm UK compression waste fitting without using a 38mm to 40mm adaptor prior?
The reason not to use an adaptor is because there is no space.
Note, a 40mm compression fitting on a 38mm pipe will hold however the joint won't be as tight, both mechanically and water pressure. Hopefully there is a way to improve the seal.
