4 Hole Bath Set Query
9 Nov 2007
Newcastle upon Tyne
Hi, everyone.
I want to install these type of taps and showerhead in a bath. www.tapstore.com/acatalog/Laser_4_hole_bath_set.html
I have found technical drawings with sizes, etc, for them but have not been able to find any info on what is needed "below the level of the bath".
At present I've got a monoblock mixer tap and what I really need to know is what fittings(?) are required between the hot and cold water supply and these taps above the bath. Obviously, the water mixes below the level of the bath.
In general, do these tap sets come with all the plumbing below the bath supplied? If anyone could post a link to the required pipework that would brilliant.
Thanks in anticipation and keep up the good work.
Stu.
All of the workings/connectors between the taps/mixer will be supplied with the taps,they usually have braided flexible hoses to join them together.You can use normal tap connectors to connect hot and cold to these units.
