- Joined
- 27 Jan 2008
- Messages
- 24,924
- Reaction score
- 2,882
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
I was reading the thread on frequent asked questions, and I do remember the death of the baby due to the header tank failing. As where the only heating of the water is electric with a single thermostat what has been said is correct.
However where other methods are also used to heat the domestic hot water, especially solid fuel although it would also apply with twin electric thermostats then a fault with the alternative form of heating can and does cause the electric back up to fail, and the over heat sensor needs to have a manual reset.
In the old days of having a side boiler on our stove, it was common to hear the water boiling, and we would have to run off some hot water, with solid fuel the header tank is not made from thermal plastic, it may be plastic, but not the type which loses it's form when it gets hot. So the tank can be full of boiling water without the danger of it failing, in the main the header tank is steel.
After the stove had cooled to use the electric immersion heater (fitted 1954) we would need to go up and press the large red reset button, all British thermostats had the reset button, it was only the cheap imports which lacked the emergency cut out.
In the main gas never boils the water, nor does electric, so having a non resettable cut out is normally not a problem, but clearly if the off peak immersion heater thermostat fails then it will trigger both the off peak and the emergency second thermostat allowing one to heat the water if off peak fails, and visa versa so with more than one heating method the cut out needs to be resettable.
The cure would be to ban thermal plastic header tanks, the non resettable cut out was a cheap fix until a better fix could be found, the worry is should a thermostat fail once, it is likely to fail again, so the non resettable cut out ensures the thermostat is changed. However this is only valid when there is only one thermostat controlling the domestic hot water, with two or more thermostats then only way to ensure the back up does not fail erroneously is to use resettable types.
And old way to stop a thermal plastic header tank failing is ban thermal plastic header tanks.
