4 Wire Thermostat... Now with pictures.
16 Sep 2007
Bristol
I am redecorating our living room and I want to change the thermostat for something newer, something easier on the eye...
There are two cables to the existing stat. It is wired from left to right earth x2, red, red (permanant live), blue, yellow wires. There is also a black wire that is just left unconnected.
What should I replace it with?
I'd like something with a digital display, can any stat be fitted or do I have to stick to the same wire configuration?
type/model of stat, type of system etc. the more info the better.
Valliant COMBI/compact boiler, a Drayton control type RTC.
Any other info needed?
Do you know where the cables go, old airing cupboard, boiler or previous boiler position
I am fairly sure they go back to the boiler. There is also a timer on the system.
In this picture the wires are labeled as:
E - EARTH
2 - COOLING - RED
1 - HEATING - RED (permanently live)
N - NETRAL - BLUE
3 - LINE - YELLOW (live when heating off and stat above room temp)
I can't advise on which model to go for but you don't have to worry much about matching the connections in line with the old one.
A modern battery powered digital thermostat will only require 2 connections.
The permanant Live and the Switched Live wires.
A traditional mechanical unit will also need the Neutral connection.
So you can please yourself and buy whichever one seems the best. Then come back if you still aren't too sure about the wiring.
I can only see three connections (plus the earth) to the thermostat itself so a mechanical one will likely use all three. Some digital ones wont need the Neutral (and possibly the Earth also) so they can just be carefully covered up and held back.
I've bought a SUNVIC TLX6501
It's connections are labelled
NO
COM
NC
Do you know which wires I should be using?
Also there is a small switch inside the unit that can be set to either HEATING or COOLING. Which do I set it to?
Heating, as it's not for Air Conditioning :p
One of those questions that sounds obvious when someone's awnsered it :)
