Hi All,
My kitchen extension was completed around a year and a half ago and has developed a major problem with the 600x600x15mm basalt (volcanic natural stone) tiles. The tiles are laid on 18mm WBP ply using Mapei Keraquick adhesive and there is NO ditra matting.
There is wet underfloor heating throughout, and the problem which has arisen is that the tiles on the ply joints have cracked which means you can see the outline of all of the 2400x1200 ply boards.
The builder isnt interested in fixing it as no decoupling layer was specified by the architect. The architect blames the builder for not switching on the underfloor heating before tiling and allowing the boards to dry out. Hence I'm left with this rather expensive problem.
My question is, should i remove only the cracked tiles, attempt to remove the adhesive and replace the cracked tiles? Or remove the whole lot and re-tile the whole area? Bearing in mind I have a flush finish with the sliding glass doors and the outside decking so if I relaid the whole floor and used 15mm tiles plus Ditra and didn't remove all of the adhesive I'd finish up high with the sliding doors and the decking.
If I did replace only the broken tiles which are in view, ie the cheaper option are there any adhesives I can use which will allow an amount of flex, for example a latex based adhesive?
Any suggestions would be greatly appreciated!
Cheers
Angus.
Cheers
Angus.
