40mm Basin Waste - Threaded to Compression
20 May 2013
Bristol
Essentially will a 40mm compression fitting be suitable for a 40mm threaded waste.
I'd like to (have to) use a bottle trap for the basin due to space constraints. The trap can't reside inside the wall hung vanity so I'll need to extend the waste to below. I can't easily see how to go to 40mm threaded waste and then extend the pipe approx. 200mm to a bottle trap before running horizontally.
I could use a P trap but this would also need to be below the vanity.
Thanks.
Thanks guys. I can't get to the back so it will have to be straight down. Phill, do you have a screwfix number? That link doesn't work for me at the moment. I think I might be able to use a pedestal trap.
