40mm Waste into Inspection Chamber
16 May 2006
Pembrokeshire
Hello
I'm putting a new sink in, and can go directly through the outside wall and about 1m away from the house is an inspection chamber (foul). Is it ok to dig down and put my 40mm waste straight into this? I understand that it's got to be angled to the direction of flow, but could I break into the brickwork or must I go deeper into the cement benching?
Thanks for your time
Connecting a waste directly to a chamber isn't standard practice, should go either into a trapped gulley connected to sewer or into a waste adapter into 110mm pipe, then to chamber. However, seen a few done like that, if it's just a sink (no WC involved via a macerator), then you would probably be ok to go through the brickwork, just fit a bend on the end to angle into direction of flow.
If Building Control are involved then would suspect you'd have to do job properly as above.
