hi I am altering the soil connection at the inspection chamber at head of drain.
it is a multi plastic chamber under 600mm deep 320mm diameter. the soil from the svp enters and exits straight through. I need to alter the position of the svp and this looks like it could connect with a 45 un used inlet. I would the blank off the 0 degree inlet.
Would this work or will i get blockages? is it better to rotate the chamber and put a 45 degree bend on the outlet?
