Not sure if this is the right place to post this but hopefully it will be posted correctly.
I have a 47Kg Propane Gas cylinder in my garden that runs my propane gas fire.
I have recently fitted a HiLo Gauge so I can check the amount of gas in the cylinder. This was placed between the regulator and the gas valve.
I am fairly sure that when the cylinder was last changed by Flogas the compression joint to the gas valve was fitted "bare" i.e no pfte tape or similar was fitted so I have done the same with the new fitting.
Is this correct please?
If not what should I use?
