4kw gas fire cost to run?
13 Oct 2006
Worcestershire
Hi guys this may(or may not) be a stupid question...I have a 4kw gas fire (88% efficient) and glass front...I pay currently just under 6p per kilowatt per hour..so if I were to have the fire on for say 5hrs @ 4kw per hour that roughly works out to approx cost of £1.20p for gas used...BUT is that what my supplier will be charging me ?( not including standing charge & VAT)..or is it worked out by my supplier a different way costing me actually more per Kwh ? Thanks
Thank you for your reply...so then in a nutshell if I were to use 200Kwh of gas exactly over 1 month my total Gas Bill from my supplier would be @ 6p per Kwh = £12.00 ( Not including Standing Charge or VAT)?
4kW is quite a lot.
More likely it will be used way below max most of the time.
Hi guys,thank you all for your replies...yes 4kw was an example to find out total charges,the fire runs at 2kw per hour most of the time . Cheers
