Hi, hope someone can help.
We have a 260L thermal store. It has 3X3kw and 1x4kw immersions.
The 4kw is the current problem. This and one of the 3's comes on for 7 hours each night (economy 7)
See the image here
As you can see the wire coming from the thermostat into the element is rather worse for wear. It came off when i poked it (all power off of course). And there's lots of moisture in there. The other odd thing is the earth nut has gone a rather attractive share of orange. I suspect some kind of chemical reaction.
Also note that i stripped all the wire back about 10cm last week due to the thermostat failing. I replaced the thermostat with one 'borrowed' from one of the other immersions that we dont usually use.
So all this has happened in a week!
Anyone care to hazard a guess as to the cause of all this?
See the image here
