5"Stove Pipe to 7" Clay Liner Chimney Question
24 May 2009
Dorset
Just had wood burning stove fitted by a HETAS registered installer and have a question.
Stove pipe is 5" and chimney inlet is a 7" clay liner. All the installer has done is insert the 5" pipe inside the 7" liner by 3 to 4". This leaves a 1" gap all the way round which is no way "gastight" Is this standard practice? Is this going to cause a problem with condensation? Should I get HETAS or building control involved?
Any suggestions?
Thanks in advance
I'm not HETAS but I'll give you some thoughts on it seeing as no one else has answered.
What does it say in the instructions?
It wont make any difference to any condensation issue.
What he has done is create a draught diverter which is usually a part of the fire. While I don't think it is dangerous at this time there is a possibilty that it could be and I would definitely seek further advice. If advice doesn't come from this site have a word with HETAS or the manufacturer.
Meanwhile you might be able to post a picture and give more information on the stove you have fitted for when or if someone more knowledgable on this subject comes along
it requires sealing into the flue.it should be flaunched into the flue so you dont get any build up of anything in the flue.
That doesn't sound like a compliant installation.
