- Joined
- 6 Mar 2007
- Messages
- 3
- Reaction score
- 0
- Country
Hi, when I turn on the dishwasher the pump runs and runs. I've checked the direction and it appears to be trying to pump water into the machine. It doesn't fill the machine with water, rather the pump keeps turning in the shallow bit of water that is left in dishwasher after each cycle. This first happened a few weeks ago so I followed some advice from the web and realised it was a float switch problem. I duly drained the collected water from the base of the dishwasher and that solved the problem.
However, a week later the same thing happened, so I drained the water out of the base again and the dishwasher worked. A few days later and the same problem has resurfaced a third time. Now I know that it's a problem with the float switch that is causing the base to flood. My question is, why does the floatswitch turn the pump on to clear the water from the base, which is outside the dishwasher cleaning compartment. Also, because this has happened three times now, is it definately a leak between the main compartment and the base, or could it be an issue with the outlet hose. I've also read that sometimes a blockage to the dishwasher outlet hose can cause a dishwasher to back fill with water. Would I be correct in assuming that this water would only fill the compartment and not migrate into the base of the machine?
Any advice would be greatly appreciated. Thanks in advance.
Dave
Dave
