550mm radiator height?
17 Sep 2011
Suffolk
Hi all,
I'm completely confused with the radiator heights in my house. I'm looking at changing a rad in my dinning room as it's just not keeping up with the poor performing patio window.
The house was built in 1992 and from what I can tell the radiators are all original fittings. I've measured every radiator in the house and they're all 550mm in height (top edge to bottom edge). I can't see any mention or anywhere that sells radiators with a height of 550mm. The annoyance is that the radiator is mounted Bottom Top Same End and was hoping to just change out the old rad with a double panel.
Am I just searching for the wrong thing? Should I be measuring from the pipe centres where mounted? Have radiator height sizes changed in the last 20 years?
Cheers
Neil
Are they round top radiators - these often came in "funny" sizes and yes there is a slow drift towards bringing them into line with panel radiators. Could they be Myson Premiers (nominally 530mm) or Rettigs? Best bet is to get a free catalogue from a PTS or Plumb Centre or somewhere and flick through, or find a knowledgeable behind the counter guy.
There are several suppliers of rads 550mm high.
Look a little harder under radiator manufacturers or call a few plumbing merchants.
Tony
Radiator sizes have indeed changed and I'm afraid that you're highly unlikely to find a 550mm high one any more. You're also reasonably unlikely to find a rad that has the tappings the same distance off the wall as your current ones, so you'd probably end up altering the pipework anyway
Thanks guys, I'll get down the local plumb centre and have a word to see what they've got.
The rads are all seamtop flat panels if that makes any difference.
