Hi all, i am looking to fit 6 bollard lamps 240v @ 40w on top of decking. The decking is raised around 500mm from ground level.
I will be running in an armoured cable to a ip65 switch which is going to be on the decking via a post of some sort.
My question is this, as all of the electrics from the switch box are under decking can i simply use 2.5mm Twin and earth with out any protection if I hang/attach to underside of decking?
This would come straight from the ip65 switch to an ip65 junction box under the decking and feed 3 of the lamps. A 2 metre run would need to go underground to the other side of the decking or I could simply run around the decking which would use up about 10m extra cable but would avoid having to lay it underground. This would terminate in another ip65 junction box then 3 cables to each lamp.
Do i need to use two junction boxes or could i simply link from one to the next as they are only 800mm apart?
Finally the lamps only come with a standard 3 way connector block which is not waterproof. This connection will be in the middle of the stainless steel post about 100mm up from decking. Will this be ok as it is or should i use glued heatshrink over the top or even consider 6 ip65 or similar connectors?
Any advice and help appreciated.
