Following on from a recent posting of mine, electrician is coming out to replace the isolator with a new 45a shower protection unit with RCD, I raised the question over whether the 6mm t&e cable would be sufficient for the new 9.5kw shower to which he said it would be, now he being a expert who am I to question, but I have seen plenty of posts stating that 10mm should be used,
I have measured the run out and would say (allowing for additional to put a new pull cord switch in) that cable length would be 13m-14m, first 4m pinned to inside of garage wall, then goes through external wall of the house, into bathroom floor pinned to joists, then up inside of stud wall to new cord switch, back down wall again across floor then up inside of other stud wall into back of new shower, are there any issues with the heat disipation of this route with the smaller cable or with the cable itself??
Many thanks,
Many thanks,
