Hi all,
I`m trying to wire a zanussi double electric oven to a ccu using a 6mm t&e cable as reconmended. The problem is the connection panel for the cooker is located in a smallish square at the bottom of the oven and the connection is not a typical " push wire into hole and secure connection with screw". It is instead simply a screw that would hold the wire in place if the wire could be connected to it. I`ve tried bending the wire around the screw but it doesnt look particularly secure and because of the size of the wire doesnt fit.
Can you get a crimp terminal big enough to secure a 6mm cable? Screwfix do one but not sure if its the right one. Crimp Yellow Ring 6mm!
Or if not has anyone any idea how to connect to a zanussi cooker? Quote 70036
