Yeah, 6 has a max rating of 46A Method 1, ie clipped direct, and a VD factor of 7.3, so 31m ish is max, but that does not take account of any correction factors, grouping, temp, etc.. or if you have a BS3036 (rewireable) fuse.
AND
You have to check that your CU and supply are up to it. If your unit has a main switch less than 100A and or a main service fuse of less than 100A then you need to upgrade. REC will help if main fuse/meter need changing.
Also, you need to update your earth bonding, both main and supplementary.
