7 inch round hole through exterior wall for flue - safe?
10 Jan 2006
I need to get a hole made through my ground floor kitchen wall for a 7 inch diameter flue pipe.
I've looked all over the web and people seem to just get busy with the drill.
My concern is, the hole needs to be at a 45 degree angle, not horizontal through the wall. My walls are 1930's solid 13". At 45 degrees, that's a lot of material out of a ground floor wall (1st floor above). I can't see a single example where anyone has ever installed a small lintel or similar for such a hole, but I'm not feeling safe about it! The diamond driller I spoke to was happy just to get busy. Never brought up the concern of if it was safe.
Can anyone advise?
Thanks for the reply. I read many threads like this. No-one seems to do into any detail of if such a hole can effect the wall.
No-one has concerns about making a 45 degree 7 inch round hole through a 13" double block solid 1930's load bearing exterior wall?
You are unlikely to be able to drill a 45° hole through a wall with a core drill.
You best bet is to remove enough material for the flue pipe to be installed comfortably then brick it in.
Before fanned flues, boiler and water heater flues were about 12" square all that went through them was a thin steel liner I have never seen any wall collapse as a result.
Google "self-corbelling effect" even if a lintel above a 2 or 3 foot window fails only a triangle of bricks above starts to drop.
Then he will save you a lot of hassle cutting out and reinstating . I presume he will fix a jig to the wall and simply drill the correct size and angle . Wet or dry drilling it`ll be messy ,
