Hello All
We have a 700mm worktop deopth (2.4m length) on order, idea is we get an extra 10cm at the back to put stuff behind sink ect.
If the base units are standard depth (wickes), so 570mm, and there is a 20mm overhand at the front, that is 590mm... which then means we end up with c110mm at the back gap.
This might be obvious but would I just buy some planed wood to run along the side/ bottom and top of the back of the base units that is 110mm wide, and then attach that to the wall?
