740mm Square Shower Tray
6 Jan 2006
Hertfordshire
Does anyone know where I can get a 740 mm square shower tray?
It's time to freshen up the bathroom and I have noted my current tray to be an uncommon size. Its a recess shower, with just a door at the front. I checked to see if some of the tray was hidden by the tiles, but it seems to be 740 square.
Any ideas??
Has to be 760mm .
Must be recessed into wall
Are you sure it aint reccesed ?
Never seen a 740mm
740 may be the dimension at the top face of the tray but remember they slope down and out so the real dimension may be 760 (a difference of 10mm at each side is about right for this slope). You can get 700 & and 760 trays.
that size was last made in the early nineties,it will be thin fibreglass on thin metal legs?idont know of any supplier who still has some in stock,you would have to recess the wall and fit a 760mm
It will be a 760 x 760, I went through this earlier this year. You will find a '760' will actually measure a little less, go to B&Q and measure one of their Mira Flight trays and see.
760 is the smallest size according to PTS.
I have the same problem. Would it not be possible to fit a 760mm square and bring the existing cubicle 1cm off the wall with some kind of spacing strip. it would only be 1 cm each side so should not look awful.
