Need some help understanding this please.
Out of curiosity I checked my shower installation from the cu side and i think its connected using 6mm cable. The total cable length is approx. 8-10 metres. The shower i have is an 8.5kw running from a 30A rewireable fuse. Its an old MEM unit.
Im confused why the fuse hasnt blown in over 15 years. Would it only blow if there was a fault somewhere? Because the max load on this cable should be about 7.2kw as i understand it? As far as i can tell the cable is partly in trunking and partly loose by the cu and under the bath. Then it is trunked again coming up to the shower. None of the cable is wall buried.
The conclusion i am arriving at is perhaps the fuse is not actually a 30A. Or maybe whoever installed it has somehow put a higher rated one in or bridged two 30A fuses on the board. But apparently 30A is the biggest available. Can anyone clarify any more on this? thanks
