I am in need for some help on my Vaillant 837 EcoTec Plus combi boiler (installed in Dec 2009) that is making noise. Same noise as in this video.
https://youtu.be/y-yMEAgEtyM
While I was decorating the house I had taken off the radiators from wall and left the thermostatic valves on closed position. After many weeks (6 wks) the water from the closed thermostatic valve leaked and emptied the water. The pressure gauge on the boiler showed zero. Using the two valves at the bottom I re-pressurised the system to approx 1.5bar.
I accidentally turned the gas inlet valve to off while I tried to de-pressurise the system after I over pressurised. I put the gas valve in fully open position after realising that did nothing to the pressure.
After this point I noticed the boiler started to make some noise (as if the low flying jet passed over my house). I felt the water was not hot as before. I called an engineer as I also needed to service the boiler and put in the radiator chemical. Engineer did the service and I also made him aware of the noise that the boiler was making.
Engineer wasn't able to diagnose the fault so he spoke to the Vaillant Technical team and they advised the noise was due to the worn out gasket seal (part no. 0020038679) on the HE. This was replaced by the engineer but the noise was still there. Spoke to the Vaillant Tech team again and another advisor told to check the standing gas pressure at the boiler and at the meter. He also checked the pressure while the boiler was running and found the pressure drop was about 7-8mb at the meter while boiler was on. He advised to have the meter and governor changed by ringing National Grid. Both items were replaced for no extra cost by National Grid and Grid engineer reported the standing pressure of 21mb and after switching the boiler on it dropped close to 19mb at the meter. 22mm pipe is installed from the meter to the boiler. I see a very small variation in the cooker flame when the boiler is switched on.
My boiler engineer tried playing with the air inlet duct and found that when the air duct is off the noise was little less. Also if the air inlet was being partially covered the noise became worse. He cleaned the duct and put it back. The noise was there.
After all the above was tried and the boiler engineer left my premises, I thought to myself, it could be something to do with me closing the gas inlet valve accidentally that I have kept it fully opened. I started playing with the gas valve by slowly closing it and finding out if the boiler made noise again when hot water is running. I found a valve position that took the noise away completely and I am not getting any noise.
Just wanted to get an opinion on what I had done (tuning the gas valve) is correct or would this harm the boiler? Or the noise that I was getting is due to something else? Your advise would be greatly appreciated.
Sorry for such a long message.
