8mm--10mm pipe size increase
29 Jan 2010
Gloucestershire
hi all......... i have an 8mm feed to all my rads via a manifold,...would it be of any benifit if when repositioning a rad,to increase the bore to 10mm just above the ceiling (downstairs rad),or might i just as well stick with the 8mm thankyou all
Is this rad a problem 'cool' rad?
You can upsize the pipe but you will need to rebalance the system as water takes the easiest path.
