I have an old imperial (approx) 1756 x 600 single with fins radiator which i plan on replacing for a type 21 radiator 1600 x 600 and using extensions to allow for the difference in pipework centres. My worry is that the 8mm microbore feeding the radiator is going to be too small to properly heat it. Its in my buy to let property and my tenant has asked for a double radiator because although the existing one is hot to the touch, its not heating up the room sufficiently. I have looked online and can see some tables showing max kw of 1.5 and others 2.5 for 8mm copper, i was just looking for others opinions?
Kind regards
Kind regards
