I am putting two new rads in my house. The other rads are fed by 8mm microbore so I want to feed the new ones with the same so as to have an even supply throughout the system. My plan for each rad is to put a 22 to 15 reducing tee on both the CH flow and the CH return and then on each 15mm line from the tees put a 15 x 8 reducing coupler to the 8mm microbore. I'm only a DIYer so I just wanted to check with the pro's that this sounds ok.
So this will involve two tees off the flow and two off the return. Is there a more efficient way to do it. I have seen 2-port 8mm manifolds but I think they involve soldering, which I've never done, so that option's out I think.
I want to put 8mm TRVs on the rads but the only one I've seen has been the Danfoss RAS-C2 in the Screwfix catalogue, where it gives the diameter as 8-10. Does this mean that it will fit both sizes?
Thanks.
Thanks.
