8mm to 15mm pipes
20 Mar 2007
Warwickshire
I am replacing a radiator in the bathroom. The existing pipes are 8mm. I want the visible pipe to be 15mm stainless steel to compliment the new radiator. Are there standard convertors that do this job and are there any points i should consider?
Cheers,
Mike.
don't use stainless use chrome :idea:
and 2 of these
If you are soldering to the chrome tube you need to scrape the chrome off the part than goes into the fitting - solder won't stick to it.
Can i use the compression type of fitting or will this be too strong for the 8mm stuff?
Sorry, I should have put chrome.
Mike.
