I’m replacing a thin and poorly insulated ceiling and dry lining some new walls in my garage/utility. The current ceiling doesn’t look to be fireboard or even doubled up.
Am I ok to board the walls with 9.5mm and then double board the ceiling? This will keep wastage at an absolute minimum.
Or should I go for the 12.5 fireboard on the ceiling and then 9.5 (or even 12.5) on the new walls?
Ceiling joists are 450mm centres. Walls I was going to do 600mm.
