90 degree downpipe bend, small size, where to buy?
16 Jul 2006
Norfolk
Hi all
I want to put some small size guttering on my workshop.
The downpipe will roughly be where the red line is in the pic below. But I will need a 90 degree bend and cant find them anywhere in the small minifit type guttering.
Any suggestions please?
I fitted the small sized guttering to my workshop. Got all my stuff from Wickes - the minifit range. The bends were 112'. Won't they do the job you want if you shorten the verticals?
Not sure if they will, but thanks anyway.
Problem is, I want to have the downpipe against the far wall in the photo, then turning 90 degrees to the right to go along the back of the house wall following the white pipe to the drain.
As these walls are 90 degrees to each other, unless I'm missing something (which wouldn't be the first time) it wouldn't work.
Don't know about downpipes, but you can get everything you need (apart from the shoe) if 50mm wastepipe would fit, which it might just
Bet it won`t fit :cry: . You need 2 bends ( 112 deg. or whatever) put one on top of the other- twist them around -and you`ll see how they can turn the corner ;) . There are no 90`s made in this size
Many thanks
Many thanks
Aw, shucks, it was nothing :LOL: :LOL: :LOL:
(If I hadn't got it wrong then maybe someone wouldn't have bothered getting it right for you!! ;) )
