hi
this is my first post here and i just wanted to say thanks to everyone here for helping me to fix my boiler, i know i didnt make any posts but i found the soloution using search
i will also post my problem and soloution in case anyone else has the same problems.
my problem was with my baxi duo combi boiler, i had hot water but no heating, everything seemed fine, the wireless thermostat was asking for gas, the light on the reciever was on, by all accounts it should have been working.
anyway i tried a few things mentioned here like shorted out the two black wires on the back of the timer but nothing worked.
then someone had mentioned shorting the two wires that go to the reciever for the thermostat, first i tested them with a meter, 230 volts going into the reciever but only 60 volts coming out, so i shorted out the two connections and the boiler fired up.
so ive disconnected the reciever completly and am using the boiler without the wireless thermostat for now.
my only question is why when i pressed the overide button on the reciever (drayton scr) did the boiler not fire up?
i would have thought it just did the same as shorting out the two terminals
thanks again guys this is a good site, i think i will stick around, being a bricklayer by trade i may be help people out myself.
