i recently had a 3 1/2 ton a/c unit installed (trane). i have two zones. house (1) & sun porch (2). when it hot outside 90 +, i can not get the house below 78. i have the thermo set at 75. there is a return on the sun porch that also draws air along with the return in the house. i have had the installer look at the installation many times and i can't get an answer why the house will not get cool. thay have said that the thermo on the porch should be set a fews degrees above what the house is set out. this way, hot air will not be drawn thru the unit. it ain't working. any ideas?thks in advance
Ivan
Ivan
