My parents have a combi system, the boiler pressure is 1.5 bar and most radiators are working fine.
There are two that are not.
It has a new combi boiler and TRV's on all rads.
I have bled these two radiators and get a constant flow of water. I assumed that air is not an issue. The TRV is set to max and I have tried half/full opening the lock shield. The tail pipes are warming up.
Also, when I bleed the rads, the water is cold.
Where do I go next?
Could I close all/most other rads and then see if heat is reaching these rads. They are the furthest away on the ground floor but we have an upstairs and rads there seem to be fine. The boiler is on the ground floor.
Thanks in advance.
Where do I go next?
Thanks in advance.
