Supplementary bonding in my bathroom.
There are no electrical services other than lighting. The bath is plastic, the pipework is copper. No metal building fabric.
1) My understanding is that I need to bond hot water pipe, cold water pipe, and CPC of the lighting circuit, and nothing else. Does that sound correct?
2) I have central heating pipes running under the floor, but they are not exposed in the room itself, nor do they contact the HW or CW pipes in the bathroom. They are bonded elsewhere. I therefore think that these should not be included in the supplementary bonding. Correct?
EDIT- Duh, Since i'm having a towel rail (when i get round to fitting it), then my flow and return will need bonding.
3) If I run the bonding conductor inside a studwork wall (for the run between lighting CPC and the pipes), Since the wall is less than 100mm (ie, 2 x 50mm) thick, then does the bonding conductor need additional protection? I'm a little unclear on this- if it was a live conductor it'd need earthed metal protection, but this conductor *is* an earth.
4) Is there any requirement for bonding straps / points of connection to be accessable, or even visible? or can they remain under the floorboards. Obviously I'm aware the the LABC monkey may want to see them, but I can lift floorboards for that.
Thanks for the info.
PS, i know all about part P, i'm doing a legal rewire.
