Our lighting curcuit doesn't have an earth I belive this is the way things where done some time ago. When we first moved in 5 years ago we had an electrical report done and all it said really was we needed some earthing put on the bath.
Is this type of curcuit safe? Assuming im only going to fit the double insulated switched and fittings on. Is this some thing I can change in a few years?
The other question is I have one plug socket that is metal but it is earthed on the back box and the actual unit is this ok?
Last question is before part P I was well underway on my loft conversion to which I needed to fit 3 interlinked mains smoke alarms. I got the 3 Kiddie units and the correct wire with the extra white cable in I ran the cable to the correct points and fitted the alarms according to the manufacturers instructions. The only thing I didnt do is connect them up to the CU. I have a seperate RCD for the smoke alarms to be fitted to on their own. Is this something I could do? Bearing in mind I could have connected them all up before part P.
Thanks.
Thanks.
