After years of avoiding doing my own plumbing I figured it's about time I gave it a go so a couple of questions.
First job it fit isolating valves to all my taps and toilets and renew my bathroom taps ....
1. Compression fittings / flexible hoses - are there any particular brands I should look out for or will the trade packs from Screwfix be decent enough?
2. Flexible hoses - just how flexible are these? On my bath taps there will be a distance of around 5" once the valve is fitted. Will 300mm be okay as I can only find push fit in 150mm.
3. Compression fittings - Am I better to use jointing compound or ptfe?
4. My cold taps are all mains fed so will use standard isolating valves. Assume it's best to use full bore valves for the hot taps? (Gravity/vented system).
5. The hot supply from my cylinder doesn't have an isolating valve. Would it be sensible to fit one whilst the tank is empty?
Thank you!
Thank you!
