Just been clearing my phone out a little and came across a few pics I don't think I have posted.
Rodents.....
A rough DIY'ers install. How can they think they have done a good job?
A poorly terminated SWA at a masterseal socket, with a PIR light fed directly from the socket. The PIR light was actually fed in 5 core flex, although looks like 1.5mm 3 core. PIR has seen better days too!
An early 17th edition install, using up some MEM split loaders from stock. There is a single main switch in the meter box.
An old voltage operated ELCB installation. Notice the peak and off peak circuits are both protected. A little bit of an odd one.
The above install had a PME conversion and a new CU. I used an MK they where on an offer at the local wholesaler at the time. Would usually have used an MEM, but had none in stock at our unit, and it would have meant travelling into town.
Not the neatest TBH, but a fairly standard 'get it in' job
There is no bonding cable present in the pic, but oil and water MEB's where added shortly after. You can see the old 6mm water bond to airing cupboard...
Rodents.....
