A few questions before tiling my kitchen floor
20 Feb 2011
Berwickshire
First off, this is what I'd be going over with nice new porcelain floor tiles-
Not sure what they're made of exactly, some kind of plastic, but they've been down for over twenty years with no signs of lifting or damage. Just a shame it's so damn ugly. It's flat and level, the white bits are raised maybe 1mm. Can I apply BAL tile adhesive straight over the top? Should I use a self levelling compound first/lift them? It's concrete or possibly screed underneath, something solid and cement based at all events.
Second, should I fit the new kitchen then tile, or tile and then fit the new kitchen?
Third, is laying porcelain floor tiles much different/more difficult than ceramic wall tiles? I did my bathroom walls and a shower enclosure a few years back and although it was very slow, I was entirely happy with the finish. Any reason I shouldn't try my hand at porkies on that basis?
There are adhesives that can (supposedly) be used over vinyl (if that’s what it is) with the correct prep but I would never risk it. An SLC could work but there is always the risk of a reaction &, personally, I would remove it; if there is bitumen based adhesive underneath, you need to remove as much of that as you can but do not use a blown lamp or any sort of solvent & additional prep will be needed.
You can do it either way but tiling after reduces the risk of clumsy fitting damage & you don’t have to fully tile under the units but make allowance for the height of the tiles & adhesive for appliances
There is no real difference when laying the tiles themselves but Porc is harder & can be more difficult to cut with a manual tile cutter so I would advise you should have a reasonable diamond wet cutter to avoid costly mistakes.
