Hi, can anyone help with the following questions?
1. Supplementary bonding – does a normal domestic electric shower require supplementary bonding? Or do you connect supplementary bonding from the copper pipes in a bath to the earthling terminal of the shower? Do you connect supplementary bonding to the shower supply pipe even if its not exposed in the same room? Also should there already be supplementary bonding on the bath pipes? A brief and simple explanation might help here, as I just don’t understand what the requirements are. pref in layman’s terms.
2. When fitting a consumer unit to an external garage, where do you connect the consumer unit to? Do you treat like a new circuit from the existing consumer unit in the house? If so what size mcb should I use, or should I use RCD integrated or separate from the consumer unit? Again would be grateful if it could be explained clearly.
3. Outside pir security light – should the cable that trails along the outside wall be protected? Currently the cable is pvc sheathed twin & earth just clipped to the wall. It is out of reach from accidental damage but is it sufficient?
