First, we are approaching our second winter season in an older house. THe top two floors are heated by a gas hot water boiler. I have, until today, neglected to bleed the system. I started on the only third floor radiator. The air kept coming and eventually slowed almost to a stop. I close this one and moved to the radiator directly below on the second floor. This radiator hissed air for a few seconds and I got water. The remainder of the rediators on the second floor were fine. I bled the third floor some more but again, never got any water. I beleive the home inspector told me as I moved in that the system would fill itself but am not certain about this. Is there anything I can do to tell if there is sufficient water in the system?
Does the hotwater in this system run in serial? (I assume no) Will shutting off a single radiator prevent flow throughout the system? (again I believe not)
Finally, the pump on my boiler has a note to lubricate the pump and motor bearings with 1/8 oz of 'lubricating oil' once per season. Can I use motor oil for this or is there a more appropriate lubricant?
Sorry for the long message. Thanks in advance for any who read and repond th this.
