A few simple questions relating to a shower waste and a sink
11 Feb 2004
Hi all
A few questions if I may - thanks in advance.
1) Do you use 40mm pipe for the waste on a shower (same as for sink waste) - there shower is high pressure and gives off a lot fo water so i need it to be efficient!
2) I have a SCS hammer drill - what should I be using to drill a hole through 2 layers of brick for the 40mm pipe? Is there a special large drill bit for the job??
3) Sink - how do i hang a sink (without pedestal) to a plasterboard cavity wall (ie sink plugs won't be enough in plasterbaord
cheers
Darren
Yes
You can buy or hire a 50 mm core drill .
Cut out some plasterboard and fix a batten between studs to hang it on. :D
