A modern alternative to Linseed Oil Glazing putty?
12 Jan 2007
Lancashire
Hi all,
Time has come to deal with some single glazed timber windows. Practically 50% of the original linseed putty has fallen out. I have about a day to get things redone.
Considering that linseed oil putty needs a day to a week to become paintable, could I use something like TIMBAGLAZE (a Chemfix product) without issue? I rarely hear this stuff being used.
Regard
U
Companies that restore windows using repair care or similar products use modern putty alternative
Hi all,
Regard
U
I have used Timbaglaze in the past. It is a MS polymer, similar to the likes of CT1 and Stixall. It is pretty thick though. Ideally you would use a high thrust ratio caulking gun.
This my go to gun for silicone, caulk and thinner MS polymers.
For thick MS polymers I use the following
Some MS polymers are so thick that on cold days you will need two hands to pull the trigger, and I have snapped a few regular guns when working with them.
I apply tape to the glass, apply the MS polymer and use a combination of silicone profiling tools and my finger to smooth them.
The following day, you can prime them with waterbased paints. Never apply oil based paints over them without a waterbased undercoat. For some strange reason, oil based undercoat applied directly will stay tacky for months.
That's pretty comprehensive advice, thank you. I have a geared gun that I bought a last year (I am sure it had a Japanese name). So I am ready for it. Right, 3 cartridges ordered, only two delivered.....this bids ill omens...
