A PIR that very quickly became a visual condition report....
It soon became obvious that rather than carrying out any testing on the 4 flats, it would be easier to do some visual condition reports and recommend rewiring....
for some reason I have managed to loose half the pics, such as some old 6mm T+E submain from a brand new wylex 60amp sw fuse, a 10mm T+E for a shower directly from the incoming terminals of a 4 way wylex rewireable CU, very badly perished VIR cables in terminal blocks to brand new T+E, 6mm cooker cable jointed with terminal blocks to some 1.5mm to a downflow heater in the bathroom....the list is almost endless.
Seems a decorator has been doing some work over the years saying he is capable. You decide!
10mm T+E fed from a 60amp sw-fuse in the room above feeding this antequated setup.
SWA installed a couple weeks ago by a sparky who has rewired one of the flats already.
Two gang switch switching two lights - oddly, they could have used one core as a feed for both switches....
A pet hate - spair conductors cut back, earth cut off.
Typical DIY decorator - Wickes CU. With upside down breakers!
