- Joined
- 11 Jan 2004
- Messages
- 43,931
- Reaction score
- 2,884
- Country
This story comes from a colleague...
A Gas engineer reported that pipework in the bathroom of a property was showing live with his voltstick.
I went along to check with a colleague, neither of our voltsticks showed any kind of voltage present on the pipework.
The power circuits were protected by a 30 mA RCD and a soft ELI test proved to be OK (can't remember the reading), MEB was in place and a ELI test from a nearby socket using the L&N of the socket and the earth wire from the Alphatek clamped onto the pipework again gave a satisfactory ELI reading.
We were about to dismiss the gas engineers report of live pipework when the central heating pump kicked in, immediately the voltstick glowed constantly indicating the presence of voltage on the pipework. It even indicated voltage on some plastic pipe feeding the hot & cold water to the wash hand basin in the bathroom.
As soon as the pump was switched off the voltage dissapeared. In an attempt to measure the voltage we used the test lamps between the electrical earth on a socket and the pipework, no voltage was indicated and the test lamps measure from 12v upwards, unfortunately we did not have a Fluke meter to measure a lower voltage. Whilst attempting to measure the voltage we inadvertently connected the test lamp between live and the pipework and the RCD tripped immediately.
My question is how can this be??? I guessed that the CH water and inhibitor was forming some kind of electrolyte in the system and as the water started to be agitated by the pump it was generating a voltage between the iron filings that collect in the CH water (Cathodic reaction I believe this is called or something like that), but I am at a loss to explain how this affected the H&C feed to the basin. I managed to offer an explanation to the customer and assured him that the electrical tests we had carried out proved that his system was safe.
I contacted the electrical technical guy who could not offer a solution but gave me a contact name and number of a technical guy on the gas side, he could offer no solution either.
Anybody shed any light?
My initial reaction is not to trust a volt stick, but apart from that am a bit flummoxed.
